difficult start S140
pepperoni
Beitrag von pepperoni » 09.04.2015, 12:04
Hallo!
One week ago.I wanted to start my setra.after not starting
for 1 year.it has much difficulty going round.first I suspected it were the batteries!but, no!can somebody tell me the troubleshooting order?what I should check step by step?!
Thanks in advance! mark
Re: difficult start S140
Beitrag von Stefan » 30.04.2015, 14:06
Hi !
please first check if the engine is not blocked (Try to turn the engine slowly with an big spanner, if you dont reach the big screw at the crankshaft, then try the compressor or alternator)
If you can turn it round try again at the electric starter. there is an second starter knob in the motor housing
if you cant turn it round, it could be that the is water or oil in the compression room - bad !
